48 x 1GE electrical ports, 4 x 10GE optical ports, PoE+
RG-S5750C-48SFP4XS-H48 x 1GE optical ports, 4 x 10GE optical ports
RG-S5750C-48GT4XS-H48 x 1GE electrical ports, 4 x 10GE optical ports
RG-S5750C-28GT4XS-H28 x 1GE electrical ports (4 x combo ports), 4 x 10GE optical ports
RG-S5750C-28SFP4XS-H28 x 1GE optical ports (4 x combo ports), 4 x 10GE optical ports
Product Model |
RG-S5750C-28GT4XS-H |
RG-S5750C-48GT4XS-H |
RG-S5750C-28SFP4XS-H |
RG-S5750C-48SFP4XS-H |
RG-S5750-48GT4XS-HP-H |
GE RJ45 port |
28 |
48 |
8 (Combo) |
n/a |
48 |
GE SFP port |
4 (Combo) |
n/a |
28 |
48 |
n/a |
10GE SFP+ port |
4 |
4 |
4 |
4 |
4 |
Card slot |
2 |
2 |
2 |
2 |
n/a |
Card type |
n/a |
ETH management port |
1 |
1 |
1 |
1 |
1 |
Console port (RJ45) |
1 |
1 |
1 |
1 |
1 |
Console port (Mini USB) |
1 |
1 |
1 |
1 |
1 |
USB 2.0 port |
1 |
1 |
1 |
1 |
1 |
Switching capacity |
216 Gbps |
256 Gbps |
216 Gbps |
256 Gbps |
176 Gbps |
Packet forwarding rate |
162 Mpps |
192 Mpps |
162 Mpps |
192 Mpps |
132 Mpps |
MAC table size |
64,000 |
64,000 |
64,000 |
64,000 |
64,000 |
20,000 |
20,000 |
20,000 |
20,000 |
20,000 |
Jumbo frame |
9216 Bytes |
9216 Bytes |
9216 Bytes |
9216 Bytes |
9216 Bytes |
Packet buffer |
32Mbit |
32Mbit |
32Mbit |
32Mbit |
32Mbit |
Maximum |
n/a |
1480W |
PoE/PoE+ enabled port |
48 |
Standard |
IEEE802.3af/at |
Dimensions(WxDxH) |
440 X 280 X 44mm |
440 X 300 X 44mm |
440 X 300 X 44mm |
440 X 340 X 44mm |
440 X 420 X 44mm |
Unit weight |
3.9kg |
4.2kg |
4.2kg |
4.7kg |
6.1kg |
1GHz qual-core processor |
Storage |
DDR4 1 GB; 512MB Flash Memory |
Data packet buffer |
4MB |
Type |
Hot swappable |
Redundancy |
1+1 |
1+1 |
1+1 |
1+1 |
1+1 |
AC frequency |
50/60Hz |
Rated AC voltage |
100~240V |
Maximum AC voltage |
90~264V |
Rated HVDC voltage |
240V DC |
Maximum HVDC voltage |
192~288V DC |
Rated DC voltage |
-36V ~ -72V DC |
Maximum power rating |
140W |
140W |
140W |
300W |
2300W |
Idle power rating |
45W |
45W |
55W |
100W |
70W |
Dissipation mode |
Number of fan |
3 |
3 |
3 |
3 |
3 |
MTBF(hours) |
555960 |
513460 |
506320 |
523510 |
451400 |
Airflow |
Safety |
EN 60960-1, IEC 60950-1 |
EN 60960-1 |
EMC |
EN 300 386 |
Emissions |
EN 55022, EN55032 |
Immunity generic |
EN 55024 |
ESD |
EN 61000-4-2 |
Radiated |
EN 61000-4-3 |
EFT/Burst |
EN 61000-4-4 |
Surge |
EN 61000-4-5 |
Conducted |
EN 61000-4-6 |
EN 61000-4-8 |
EN 61000-4-11 |
Harmonics |
EN 61000-3-2 |
Flicker |
EN 61000-3-3 |
Anti-gas corrosion |
0 ℃ ~ 50 ℃ |
-40 ℃ ~ 70 ℃ |
10%~90% RH |
5%~95% RH |
Operating altitude |
-500 ~ 5000m |
Ethernet |
VLAN |
MAC |
ARP |
STP |
ERPS |
L2 multicast |
QinQ |
IPv4 unicast routing |
IPv6 unicast routing |
IPv6 feature |
Multicast routing |
DHCP |
MPLS |
MPLS L3 VPN |
BFD |
DLDP |
LLDP |
RLDP |
VSU |
VRRP |
VRRPv3, VRRP+ |
REUP |
GR |
RNS |
Stream classification |
Shaping |
Congestion avoidance |
RED, WRED, Tail drop |
Congestion management |
ACL entries |
3500 IPv4/v6 rules |
ACL type |
ARP security |
Attack defense |
IP |
DHCP |
AAA |
IEEE802.1X |
Web portal |
Login |
File |
Network |
Application |
Mirroring |
Hardware monitoring |
Module |
M5000H-01QXS |
M5000H-04XS |
Power Supply |
RG-M5000E-AC500P |
RG-PA1150P-F |
RG-PA150I-F |
RG-PA70I |
RG-PD70I |
Transceiver |
FE-SFP-LX-MM1310 |
FE-SFP-LH15-SM1310 |
Mini-GBIC-SX-MM850 |
Mini-GBIC-LX-SM1310 |
Mini-GBIC-LH40-SM1310 |
Mini-GBIC-ZX50-SM1550 |
Mini-GBIC-ZX80-SM1550 |
Mini-GBIC-ZX100-SM1550 |
40G-AOC-5M |
40G-QSFP-SR-MM850 |
40G-QSFP-LR4 SM1310 |
Contacte-nos
