200GE access switch (one 200GE port split into two 100GE ports), and 400GE ZR/ZR+ optical modules for interconnection at the maximum distance of 120 km
48 x 100GE ports and 8 x 400GE ports
RG-S6580-24DC8QC24 x 200GE Optical Ports, 8 x 400GE Optical Ports
RG-S6580-48CQ8QC |
RG-S6580-24DC8QC |
Ports |
48 × 100GE ports (DSFP) + 8 × 400GE ports (QSFP-DD) |
24 × 200GE ports (QSFP56) + 8 × 400GE ports (QSFP-DD) |
Expansion Modules |
Not supported |
Expansion Module Slots |
Two power supply module slots (1+1 redundancy) Six fan module slots (5+1 redundancy; at least 5 fan modules are required) |
Management Port |
Switching Capacity |
16.0 Tbps |
Packet Forwarding Rate |
5350 Mpps |
802.1Q VLAN |
4094 |
Dimensions |
Dimensions (W × D × H) |
442 mm x 700 mm x 44 mm (17.40 in. x 27.56 in. x 1.73 in., 1 RU) |
442 mm x 670.8 mm x 43.6 mm (17.40 in. x 26.41 in. x 1.72 in., 1 RU) |
Chassis with six fan modules and two power supply modules: 11.5 kg (25.35 lbs.) |
Chassis with six fan modules and two power supply modules: 11 kg (24.25 lbs.) |
Power Input |
AC input RG-PA1200I-F module ● Rated voltage: 110 V AC/220 V AC ● Rated voltage range: 100 V AC to 127 V AC (50 Hz to 60 Hz), rated current: 13.8 A ● Rated voltage range: 200 V AC to 240 V AC (50 Hz to 60 Hz), rated current: 8.5 A ● Max voltage range: 90 V AC to 264 V AC (47 Hz to 63 Hz)
HVDC input RG-PA1200I-F module ● Rated voltage: 240 V DC ● Max voltage range: 180 V DC to 300 V DC ● Max input current: 6.5 A |
Maximum Power Consumption |
● Max: 742 W ● Typical: 633 W ● Static: 178 W |
● Max: 850 W ● Typical: 700 W ● Static: 300 W |
Temperature Alarm |
Temperature alarms and overheat protection |
Operating Temperature |
0ºC to 40ºC (32ºF to 104ºF) |
Storage Temperature |
Operating Humidity |
Working altitude |
Software Specifications |
RG-S6580-48CQ8QC |
RG-S6580-24DC8QC |
L2 Protocols |
IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), Jumbo Frame (9 KB) |
L3 Protocols (IPv4) |
IPv6 Basic Protocols |
IPv6 Features |
ACL |
ACL 80、ACL-based Redirection、IPv6 ACL、Extended/Standard IP/MAC-based ACL、Time-based ACL、Global ACL、When an ACL is applied to different physical interfaces or SVIs, resources can be shared.、ACL Counter、ACL Counter Only、ACL Logging、Diplaying ACL Resource Usage、Expert-level ACL、IPv4 UDF ACL、Global ACL Counter Only、Matching Against the Inner 5-Tuple of the VXLAN、IPv6 UDF ACL、Matching Against the Inner 5-Tuple of the Passing VXLAN、Ingress/Egress ACLs |
ACL80、ACL-based redirection、IPv6 ACL、Extended/Standard IP ACL、Extended MAC ACL、Time-based ACL、Global ACL、Resource sharing in the case of applying an ACL on different physical ports or SVIs、ACL counter、ACL counter only、ACL logging、Displaying ACL resource usage、ACL-based re-marking、Expert-level ACL、IPv4 user-defined function(UDF) ACL、Configuring ACL counter-only globally、ACL matching against the inner 5-tuple of VXLAN packets、IPv6 UDF ACL、ACL matching against the inner 5-tuple of packets passing through the VXLAN |
Data Center Features |
Visualization |
gRPC sFlow sampling |
QoS |
Mapping of IEEE 802.1p, DSCP, and ToS priorities ACL-based traffic classification Priority marking/remarking Multiple queue scheduling mechanisms, including SP, WRR, WFQ, DRR, SP+WRR, SP+WFQ, and SP+DRR Congestion avoidance mechanisms such as WRED and tail discarding |
HA Design |
Security Features |
Network foundation protection policy (NFPP), CPP, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, broadcast packet suppression, hierarchical user management |
Management Mode |
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and temperature alarm |
Other Protocols |
Specifications |
RG-S6580-48CQ8QC |
RG-S6580-24DC8QC |
Safety |
● GB 4943.1 |
● EN 55032 ● BS EN 55032 ● EN 55035 ● BS EN 55035 ● EN 61000-3-2 ● EN 61000-3-3 ● BS EN 61000-3-2 ● BS EN 61000-3-3 ● EN 300 386 ● GB/T 9254.1 |
● GB/T 9254.1 ● VCCI-CISPR 32:2016 |
Environment |
Product Model |
RG-S6580-48CQ8QC |
48 × 100GE DSFP ports + 8 × 400GE QSFP-DD ports Two power slots and six fan slots The chassis is installed with two RG-PA1200I-F modules and six M1HFAN II-F fan modules. |
RG-S6580-24DC8QC |
24 × 200GE QSFP56 ports + 8 × 400GE QSFP-DD ports Two power slots and six fan slots The chassis is installed with two RG-PA1200I-F modules and six M1HFAN II-F fan modules. |
Product Model |
RG-PA1200I-F |
1200 W AC module (AC/240 V HVDC) |
Product Model |
M1HFAN II-F |
Fan module (front-to-rear ventilation) |
Product Model |
400G-QDD-SR8-MM850 |
400G-QDD-DR4-SM1310 |
400G-QDD-FR4-SM1310 |
Product Model |
100G-AOC-5M |
100G-AOC-10M |
100G-QSFP-SR-MM850 |
100G-QSFP-iLR4-SM1310 |
100G-QSFP-LR4-SM1310 |
100G-QSFP-ER4-SM1310 |
Contacte-nos
