four service slots, 25GE/40GE/100GE line cards
RG-S6510-32CQ32×100G ports
RG-S6510-48VS8CQNumber of IPv4/IPv6 host routing entries: 128K/64K
RG-S6510-4C |
Ports |
25GE, 40GE, and 100GE ports |
Slots |
4 |
Expansion Modules |
M6500-24VS2CQ, M6500-08CQ, M6500-16QXS |
Expansion Module Slots |
Management Port |
Switching Capacity |
6.4 Tbps |
Packet Forwarding Rate |
2030 Mpps |
802.1Q VLAN |
4094 |
Dimensions |
442 mm x 520 mm x 86 mm (17.40 in. x 20.47 in. x 3.39 in., 2 RU) |
About 14 kg (30.86 lbs., including power supply modules and fan modules) |
AC |
Rated voltage: 110 V/220 V Rated voltage range: 100 V AC to 240 V AC, 50 Hz to 60 Hz Maximum voltage range: 90 V AC to 264 V AC, 47 Hz to 63 Hz Rated input current: 5 A to 10 A |
High-voltage DC |
RG-PA800I-F module ● HVDC voltage range: 180 V DC to 310 V DC ● Rated voltage: 240 V DC ● Max input current: 5 A RG-PD800I-F module ● Rated voltage range: –36 V DC to –72 V DC ● Rated voltage: –48V DC ● Max input current: 23 A |
Maximum Power Consumption |
● Max: 650 W ● Typical: 455 W ● Static: 202 W |
Operating Temperature |
0ºC to 40ºC (32ºF to 104ºF) |
Operating Humidity |
10% RH to 90% RH (Non-condensing) |
Working altitude |
Software Specifications |
RG-S6510-4C |
Virtual Switching Unit 3.0 |
L2 Protocols |
L3 Protocols (IPv4) |
IPv6 Basic Protocols |
IPv6 Features |
Data Center Features |
VXLAN routing and VXLAN bridging EVPN VXLAN IPv6 VXLAN over IPv4 PFC, ECN, and other data center features RDMA M-LAG OpenFlow 1.3 |
Visualization |
gRPC sFLOW sampling INT |
ACL |
Standard IP-based ACL、Extended MAC-based ACL、Extended IP-bsaed ACL、Expert-level ACL、ACL 80、IPv6 ACL、ACL Logging、Ingress/Egress ACLs、ACL Counter (Ingress and egress counters are supported in interface or global configuration modes)、ACL Re-marking、Global ACL、ACL-based Redirection、Displaying ACL Resources、Processing First Packet of TCP Handshake When Binding the ACL to Restrict SIP、Matching Against 5-Tuple of Pass-by VXLAN Inner IP Packets、The expert-level ACL supports matching the IP flag and DSCP fields of VXLAN inner packets |
QoS |
Virtualization |
Virtual Switching Unit |
Buffer Management |
Buffer status monitoring and management, and identification of burst traffic |
HA Design |
GR for RIP/OSPF/BGP, BFD, REUP dual-link fast switching and RLDP unidirectional link detection, 1+1 power redundancy, and fan redundancy, and hot swapping for all cards and power supply modules |
Security Features |
Network Foundation Protection Policy (NFPP), CPP, DDoS attack defense, illegitimate data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, gateway ARP spoofing prevention, and ARP check |
Management Mode |
SNMP v1/v2c/v3, Netconf, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, Syslog, SPAN/RSPAN, Telemetry, ZTP, Python, fan and power supply alarm, and temperature alarm |
Other Protocols |
Specification |
RG-S6510-4C |
Safety |
● NM EN 62368-1 ● NM CEI62368-1 ● IEC 62368-1 ● EN 62368-1 ● BS EN 62368-1 ● UL 62368-1 ● CSA C22.2#62368-1 ● GB 4943.1 |
● EN 61000-4-2 ● EN 61000-4-3 ● EN 61000-4-4 ● EN 61000-4-5 ● EN 61000-4-6 ● EN 61000-4-11 ● EN 55032 ● EN 55035 ● EN 61000-3-2 ● EN 61000-3-3 ● EN IEC 61000-3-2 ● EN IEC 61000-3-3 ● EN 300 386 ● ETSI EN 300 386 ● NM EN 55035 ● NM EN 61000-3-2 ● NM EN 61000-3-3 ● BS EN 55032 ● BS EN 55035 ● BS EN 61000-3-2 ● BS EN 61000-3-3 ● CNS 13438 ● FCC CFR Title 47, Part 15, Subpart B ● ANSI C63.4-2014 ● ICES-003 Issue 7 ● GB/T 9254.1 |
Environment |
Product Model |
RG-S6510-4C |
Four expansion module slots, supporting hot swapping. |
RG-PA800I-F |
M6500-FAN-F |
Product Model |
M6500-08CQ |
Eight QSFP28 ports The QSFP28 port supports a speed of 40 Gbps/100 Gbps. |
M6500-24VS2CQ |
24 25GE SFP28 ports and two QSFP28 ports SFP28 supports a speed of 10G/25G rates. The QSFP28 port supports a speed of 40 Gbps/100 Gbps. One QSFP port can be split into four 10GE or 25GE ports. |
M6500-16QXS |
16 QSFP ports |
Product Model |
100G-QSFP-SR-MM850 |
100G-QSFP-LR4-SM1310 |
100G-QSFP-iLR4-SM1310 |
100G-QSFP-ER4-SM1310 |
100G-AOC-5M |
100G-AOC-10M |
Product Model |
40G-QSFP-SR-MM850 |
40G-QSFP-LR4-SM1310 |
40G-QSFP-LSR-MM850 |
40G-QSFP-iLR4-SM1310 |
40G-QSFP-LX4-SM1310 |
40G-AOC-30M |
40G-AOC-5M |
Product Model |
VG-SFP-LR-SM1310 |
VG-SFP-AOC5M |
Product Model |
XG-LR-SM1310 |
XG-SFP-ZR-SM1550 |
XG-SR-MM850 |
Product Model |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
Product Model |
Mini-GBIC-GT(F) |
Contacte-nos
