RG-S5300-24GT4XS-E Switches - 1
RG-S5300-24GT4XS-E Switches - 2
RG-S5300-24GT4XS-E Switches - 3
RG-S5300-24GT4XS-E Switches - 4
RG-S5300-24GT4XS-E Switches - 5
RG-S5300-24GT4XS-E Switches - 6
RG-S5300-24GT4XS-E Switches - 7
RG-S5300-24GT4XS-E Switches - 8
RG-S5300-24GT4XS-E Switches - 9
RG-S5300-24GT4XS-E Switches - 10
RG-S5300-24GT4XS-E Switches - 11
RG-S5300-24GT4XS-E Switches - 12
RG-S5300-24GT4XS-E Switches - 13
RG-S5300-24GT4XS-E Switches - 14
RG-S5300-24GT4XS-E Switches - 15
RG-S5300-24GT4XS-E Switches - 16
RG-S5300-24GT4XS-E 24-Port GE Layer 3 Managed Access Switch, 4-Port 10GE Uplink
  • Rich port types, 24 x 10/100/1000BASE-T ports for access, 4 x 1GE/10GE SFP+ ports for uplink
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
RG-S5300-24GT4XS-P-E
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
3 MB
Number of VRFs
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
Maximum input current: 2 A
55 W
65 W (without PoE load)
410 W (full PoE load)
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
2.7 kg (5.95 lbs)
3.0 kg (6.61 lbs)
3.0 kg (6.61 lbs)
3.83 kg (8.44 lbs)
4.20 kg (9.26 lbs)
4.60 kg (10.14 lbs)
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
27°C (80.6°F): 40.9 dB
45°C (113°F): 48.8 dB
27°C (80.6°F): 40.3 dB
45°C (113°F): 53.1dB
27°C (80.6°F): 33.5 dB
45°C (113°F): 53.9 dB
Air discharge: 8 kV
Contact discharge: 6 kV
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
RG-S5300-E Series
OSPFv2 and OSPFv3
Routing policy
IPv4/VRF
RADIUS
CLI (Telnet/Console)
SNMP v1/v2c/c3
RG-S5300-24GT4XS-P-E:
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
XG-SFP-T
Contacte-nos
Contacte-nos
Contacte-nos
Contacte-nos
