RG-N18014-E Switches - 1
RG-N18014-E Switches - 2
RG-N18014-E Switches - 3
RG-N18014-E Switches - 4
RG-N18014-E Switches - 5
RG-N18014-E Switches - 6
RG-N18014-E Switches - 7
RG-N18014-E Switches - 8
RG-N18014-E Switches - 9
RG-N18014-E Switches - 10
RG-N18014-E Switches - 11
RG-N18014-E High-density Large-buffer Core Switch for Cloud Architecture Network
RG-N18014-E
Front Panel
Rear Panel
Eight line card slots,
M18000E-8SFX
8 x SFX 10GE ports
M18000E-8SFG
8 x SFG GE ports
M18000E-HCA
20 x 10GE optical ports
4 x 100GE optical ports
Low CPU usage Low CPU usage
Faulty Optical Port Isolation
Visualization Visualization
Virtualization Virtualization
RG-N18010-E
RG-N18014-E
2 x supervisor module slots
8 x line card slots
4 x power module slots
12 x line card slots
Supervisor module
M18000E-CM
M18000E-CM II
Note: The supervisor modules of the M18000E-CM and M18000E-CM II are incompatible with each other. Do not insert them into the same chassis. The main program versions of the two supervisor modules are independent.
Switch fabric module
M18010E-FE-X I
M18000E-FE-X II
M18000E-FE-X II
Line card
M18000E-48GT4XS-XA
M18000E-48SFP4XS-XA
M18000E-24GT8SFP8XS-XA
M18000E-32XS-XB
M18000E-52XS-XB
M18000E-12CQ-XB
M18000E-8SFG
M18000E-8SFX
M18000E-HCA (modular line card)
● HCA-4CQ (modular port adapter)
● HCA-20XS (modular port adapter)
RG-PA600I
RG-PA1600I
M10C-FAN (pre-installed 2)
M14FAN-F (pre-installed 2)
Module management port
Supervisor module:
● 1 x RJ45 console port
● 1 x RJ45 MGMT port
Switch fabric module:
Supervisor module: 1 x USB 2.0 port (no capacity limit, 2G/4G/8G/16G/32G capacity tested)
RG-N18010-E
RG-N18014-E
14,200 Mpps
21,000 Mpps
19.2 Tbps
28.8 Tbps
Supervisor module:
● M18000E-CM: quad-core CPU, each core with the clock speed of 2.2 GHz
● M18000E-CM II: octa-core CPU, each core with the clock speed of 2.2 GHz
● Quad-core CPU, each core with the clock speed of 2.2 GHz
Line card:
● M18000E-XA/XB/CWDM card: quad-core CPU, each core with the clock speed of 2.2 GHz
● M18000E-HCA: octa-core CPU, each core with the clock speed of 2.2 GHz
M18000E-CM/CM II: supported
M18000E-CM/CM II: 16 MB
XA/XB/CWDM/FE card: 16 MB
M18000E-HCA: 16 MB
M18000E-CM: 8 GB
M18000E-CM II: 16 GB
XA/XB/CWDM/FE card: 8 GB
M18000E-HCA: 16 GB
M18000E-CM: 4 GB DDR4
M18000E-CM II: 16 GB DDR4
XA/XB/CWDM/FE card: 4 GB DDR4
M18000E-HCA: 16 GB DDR4
XA card: 4 MB
XB/CWDM/HCA card: 35 MB
Number of MAC address
● XA card: 4,000
● XB card: 10,000
● HCA card: 10,000
● XA card: 96,000 (installed without the HCA card); 150,000 (installed with the HCA card)
● XB card: 256,000 (installed without the HCA card); 512,000 (installed with the HCA card)
● HCA card: 512,000
XB card: 96,000
HCA card: 96,000
XA card: 4,000
XB card: 4,000
HCA card: 4,000
HCA card: 1,000,000
XA card: 2,000
XB card: 2,000
HCA card: 2,000
XA card:
● Ingress: 7,000
● Egress: 1,500
XB card:
● Ingress: 28,000 (installed without the HCA card); 24,000 (installed with the HCA card)
● Egress: 4,000
HCA card:
● Ingress: 24,000
● Egress: 4,000
RG-N18010-E
RG-N18014-E
4 x pluggable power modules
RG-PA600I (AC input):
RG-PA1600I (AC input):
● Maximum input current: 16 A
RG-PA600I: 600 W
RG-PA1600I:
Module power consumption
Supervisor module:
● M18000E-CM: < 60 W
● M18000E-CM II: < 70 W
● M18000E-FE-X II: < 160 W
Line card:
● M18000E-48GT4XS-XA: < 85 W
● M18000E-48SFP4XS-XA: < 117 W
● M18000E-24GT8SFP8XS-XA: < 95 W
● M18000E-32XS-XB: < 149 W
● M18000E-52XS-XB: < 250 W
● M18000E-12CQ-XB: < 240 W
● M18000E-8SFG: < 250 W
● M18000E-8SFX: < 250 W
● M18000E-HCA: < 280 W
● HCA-20XS: < 30 W
● HCA-4CQ: < 20 W
● M18000E-FE-X I: < 50 W
Fan module:
● M10C-FAN: < 216 W
Fan module:
● M14FAN-F: < 360 W
RG-N18010-E
RG-N18014-E
442.0 mm x 561.0 mm x 442.5 mm (17.40 in. x 22.09 in. x 17.42 in., cable management bracket excluded)
442.0 mm x 670.1 mm x 442.5 mm (17.40 in. x 26.38 in. x 17.42 in., cable management bracket included)
442.0 mm x 561.0 mm x 605.1 mm (17.40 in. x 22.09 in. x 23.82 in., cable management
bracket excluded)
442.0 mm x 670.1 mm x 605.1 mm (17.40 in. x 26.38 in. x 23.82 in., cable management
bracket included)
845.0 mm x 685.0 mm x 770.0 mm
(33.27 in. x 26.97 in. x 30.31 in.)
860.0 mm x 670.0 mm x 887.0 mm
(33.86 in. x 26.38 in. x 34.92 in.)
10 RU
14 RU
43.6 kg (96.12 lbs, empty chassis with 2 fan modules)
68.3 kg (150.58 lbs, empty chassis with 2 fan modules)
68.3 kg (150.58 lbs)
82.5 kg (181.88 lbs)
RG-N18010-E
RG-N18014-E
Supervisor module and switch fabric module: front-to-rear airflow
35°C (95°F): 55.9 dB
50°C (122°F): 73.4 dB
Supervisor module redundancy
Switch fabric module redundancy
1+N redundancy
N+M redundancy (same model)
Module hot swapping
Monitoring of the model, temperature, power, and voltage of the power module
Over-temperature alarming
Service port: 4 kV
RG-N18010-E
RG-N18014-E
RG-N18000-E Series
IPv4 and IPv6 GRE tunnel
MLDv1 snooping
MPLS L3VPN
MPLS 6VPE and MPLS 6PE
MPLS IPv6
IEEE 802.1p
IEEE 802.1X
IPv4/IPv6 ECMP
1+N redundancy for switch fabric modules
1+1 redundancy for fan modules.
VLAN mirroring
FTP, SFTP, TFTP, and Xmodem
Web-based NMS
LAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv6
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
Layer 2 VXLAN bridge
Layer 3 VXLAN gateway
RG-N18010-E
RG-N18014-E
M18000E-CM
M18000E-CM II
Power Modules and Fan Modules
RG-PA600I
600W AC power module, supporting redundancy
RG-PA1600I
SFUs
M18010E-FE-X I
M18000E-FE-X II
M18000E-32XS-XB
32 x 1GE/10GE SFP+ ports (LC)
M18000E-52XS-XB
52 x 1GE/10GE SFP+ ports (LC)
M18000E-12CQ-XB
12 x 40GE/100GE QSFP28 ports (LC/MPO)
24 x 10/100/1000BASE-T ports, 8 x 1GE SFP ports (LC), 8 x 1GE/10GE SFP+ ports (LC)
M18000E-48GT4XS-XA
48 x 10/100/1000BASE-T ports, 4 x 1GE/10GE SFP+ ports (LC)
M18000E-48SFP4XS-XA
48 x 1GE SFP ports (LC), 4 x 1GE/10GE SFP+ ports (LC)
M18000E-8SFX
CWDM line card for RG-N18000-E series core switches, providing 8 x SFX ports (64 x 10GE logical channels).
M18000E-8SFG
CWDM line card for RG-N18000-E series core switches, providing 8 x SFG ports (64 x 1GE logical channels)
M18000E-HCA
HCA-20XS
20 x 1GE/10GE SFP ports (LC)
HCA-4CQ
4 x 40GE/100GE QSFP28 ports (LC/MPO)
  • 1GE/10GE SFP+ ports support 1GE SFP transceivers and 10GE SFP+ transceivers.
CWDM Transceiver
SFG-LR-SM
SFX-LR-SM
Contacte-nos
Contacte-nos
Contacte-nos
Contacte-nos
