RG-CS86-48MG4VS2QXS-UPD 48-Port Ruijie Cloud-Managed Multi-GE Switch, Full 1/2.5/5GE Access with PoE++
Diverse access rates: 5 Gbps/2.5 Gbps/1 Gbps/100 Mbps Multiple power modes: PoE/PoE+/PoE++ 4 x 25GE SFP28 ports and 2 x 40GE QSFP+ ports for uplink, enabling flexible networking and high-performance campus networks
  • 48 x 5GE/2.5GE/GE/100M Base-T Ethernet ports for access, 4 x 25GE SFP28 ports and 2 x 40GE QSFP+ ports for uplink, meeting high-bandwidth campus network demands
48 x service ports: 5 Gbps/2.5 Gbps/1 Gbps/100 Mbps access, 4 x 25GE SFP28 ports and 2 x 40GE QSFP28 ports for uplink, enabling flexible networking High-power PoE++, offering up to 90 W output and adapting to services in Wi-Fi 6E and Wi-Fi 7 eras
Multi-GE Switch
RG-CS86-24MG4VS-UP
RG-CS86-24XMG4XS4VS-UPD
RG-CS86-12XMG4VS-UP
Fixed Service Port
4 x 10GE/25GE SFP28 ports
4 x 10GE/25G SFP28 ports
Fan modules
2 fixed fans
3 modular fans
3 modular fans
2 fixed fans
Power modules
1 Built-in power module
Fixed Management Port
1 x MGMT port
1 x MGMT port
1 x MGMT port
1 x MGMT port
440 Gbps/2.56Tbps
840 Gbps/2.56Tbps
760Gbps/2.56Tbps
440 Gbps/2.56Tbps
(Actual)
327 Mpps
625 Mpps
565 Mpps
327 Mpps
MAC Table Capacity
32,768
IPv4 Unicast Routes
IPv4 Multicast Routes
IPv6 Unicast Routes
IPv6 Multicast Routes
In: 2,500
Out:1,000
3.65 kg (8.82 lbs)
6.11 kg (13.47 lbs)
6.11 kg (13.47 lbs)
3.65 kg (8.82 lbs.)
Typical Power Consumption
Full PoE load: < 370 W
Full PoE load: < 1600 W
Full PoE load: < 1650 W
Power Module Model
RG-PA1000P-F
RG-PA1000P-F
Rated Input Voltage
Frequency: 50/60 Hz
AC Input
Frequency: 50/60 Hz
Rated current per circuit: 8 A
AC Input
Frequency: 50/60 Hz
AC Input
Frequency: 50/60 Hz
AC Input
Frequency: 50/60 Hz
Frequency: 50/60 Hz
PoE-capable Port
Surge Protection
6 kV
6 kV
6 kV
6 kV
Temperature Monitoring
Temperature alarm
Temperature alarm
Temperature alarm
Temperature alarm
RG-CS86-24MG4VS-UP
RG-CS86-12XMG4VS-UP
GR for RIP, OSPF, BGP
Switch and Power Module
RG-CS86-24MG4VS-UP
fixed AC power supply and fan
RG-CS86-12XMG4VS-UP
GE Optical Module
10GE Optical Module
50 μm/125 μm: 66 m over MMF
2000 MHz·km: 300 m over MMF
25GE Optical Module
40GE Optical Module
Contacte-nos
Contacte-nos
Contacte-nos
Contacte-nos
