  • Various port combinations, surge protection greater than 8 kV, PoE+, 16 × 10/100/1000Mbps copper ports with auto-negotiation, 2 × Gigabit/5G copper ports, and 2 × 10G uplink fiber ports
This switch provides 16 × 1G Ethernet ports with auto-negotiation, 2 × 5G electrical ports, 2 × 10G uplink optical ports, rich interfaces, and is PoE+ compatible, supporting full service expansion.
Fixed single AC power supply
1000
Ingress: 1500
16 MB flash memory
16 MB flash memory
16 MB flash memory
8 MB
8 MB
8 MB
< 60 W (with PoE full load)
< 15 W
< 150 W (with PoE full load)
40°C (104°F): > 300K
Rack: (32°F to 113°F)
2 x 1/10G SFP+ ports
2 x 1G SFP optical ports
256 MB flash memory
256 MB flash memory
256 MB flash memory
12 MB
12 MB
12 MB
2 x 1G SFP ports
2 x 1G/10G SFP+ ports
2 x 1G/10G SFP+ ports,
68.44 Mpps
16 Mpps
92 Gbps
21 Gbps
2.81 kg (6.20 lbs)
256 MB flash memory
256 MB flash memory
256 MB flash memory
12 MB
12 MB
12 MB
Contacte-nos
Contacte-nos
Contacte-nos
Contacte-nos
