RG-S2915-48GT4MS-L |
RG-S2915-24GT4MS-L |
RG-S2915-24GT4MS-P-L |
RG-S2915-10GT2MS-P-L |
Fixed Service Ports |
Power modules |
1 fixed power module |
Fans modules |
2 fixed fans |
0 |
2 fixed fans |
1 fixed fans |
Fixed management ports |
Packet forwarding rate |
87 Mpps |
51 Mpps |
51 Mpps |
22.5 Mpps |
System Switching capacity |
116Gbps |
68Gbps |
68Gbps |
30Gbps |
MAC Table Capacity |
16,000 |
16,000 |
16,000 |
16,000 |
ARP table |
512 |
64 |
ACL entries |
500 |
2.8 kg (6.17 lbs) |
2.5 kg (5.51 lbs) |
2.8 kg (6.17 lbs) |
2.5 kg (5.51 lbs) |
Storage |
Power and Consumption |
< 30 W |
< 15.6 W |
Rated input voltage |
>200K |
>200K |
>200K |
>200K |
Operating Temperature |
0°C to 45°C (32°F to 113°F) |
Storage Temperature |
Operating Humidity |
Storage Humidity |
Operating noise |
≤ 37 dB |
Fanless |
≤ 39 dB |
≤ 37 dB |
Interface surge protection |
Feature |
Ethernet switching |
802.3az EEE |
IEEE 802.1Q (4,094 VLANs) |
Port based VLAN |
Basic QinQ Selective QinQ |
LACP (IEEE 802.3ad) |
IP service |
ARP |
DHCP snooping |
IP routing |
RIP, RIPng |
OSPFv2 |
Port traffic rate limiting |
RADIUS and TACAS+ |
HTTPS |
SSHv1, SSHv2 |
IGMP V1,V2 snooping |
IP Source Guard |
RLDP |
RSPAN |
sFlow |
NTP |
TFTP client |
SNMP v1/v2c/v3 |
2.5G-SFP-LX03-SM1310-BIDI-I |
2.5G-SFP-LX03-SM1550-BIDI-I |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LH40-SM1550-BIDI |
Contacte-nos
