RG-DEMUX-24LC/LC |
RG-DEMUX(C)-24LC/LC |
RG-DEMUX-48LC/LC |
RG-MUX-24LC/LC |
RG-MUX(C)-24LC/LC |
RG-MUX-48LC/LC |
Name |
48-port demultiplexer |
3 groups |
3 groups |
6 groups |
3 groups |
3 groups |
3 groups |
Installation location |
Core side |
Core side |
Core side |
Building side |
Building side |
Building side |
24 |
24 |
48 |
24 |
24 |
48 |
Dimension (W × D × H) |
216.4 mm * 207 mm *33 mm |
216.4 mm * 207 mm * 33 mm |
210.2 mm * 440 mm * 39.8 mm |
RG-DEMUX-48LC/LC |
48-port demultiplexer, with 6 demultiplexing ports (number of trunk fiber-optic cables can be connected) |
Center wavelength |
1271 nm to 1571 nm (CWDM) |
Channel spacing |
20 nm |
Channel bandwidth |
± 6.5 nm |
Insertion loss |
Return loss |
>45 dB |
Polarization dependent loss |
< 0.3 dB |
Adjacent channel isolation |
>25 dB |
>35 dB |
Connector |
LC/UPC |
-40°C to 85 °C |
10% to 90% RH |
5% to 90% RH |
Standards |
3.49 kg (net weight) |
RG-MUX-48LC/LC |
48-port transparent multiplexer, with 6 demultiplexing ports (number of trunk fiber-optic cables can be connected) |
Center wavelength |
Channel spacing |
20 nm |
Channel bandwidth |
±6.5 nm |
Insertion loss |
Return loss |
> 45 dB |
< 0.3 dB |
>25 dB |
>35 dB |
Connector |
LC/UPC |
-40°C to 85 °C |
10% to 90% RH |
5% to 90% RH |
Standards |
3.01 kg (net weight) |
Contacte-nos
